Посыпался винт? Гляньте на СМАРТ
kol
З нами з: 26 листопада 2012, 17:09
Повідомлення kol » 22 січня 2016, 21:48
Насколько я понимаю, ноутбучный винт начал сыпаться. Гляньте СМАРТ, пожалуйста.
Можно еще поюзать или уже менять? Насколько вероятно, что начнет лавинно обсыпаться?
Блин, не такой старый этот ноут
Код: Виділити все
smartctl 6.4 2014-10-07 r4002 [x86_64-linux-4.2.0-23-generic] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, http://www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Momentus 5400.6
Device Model:     ST9500325AS
Serial Number:    S2WJAYSA
LU WWN Device Id: 5 000c50 050e50dba
Firmware Version: 0005HPM1
User Capacity:    500 107 862 016 bytes [500 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Fri Jan 22 21:40:16 2016 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 137) minutes.
SCT capabilities: 	       (0x103f)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   117   099   006    Pre-fail  Always       -       141410193
  3 Spin_Up_Time            0x0002   099   099   000    Old_age   Always       -       0
  4 Start_Stop_Count        0x0033   098   098   000    Pre-fail  Always       -       2682
  5 Reallocated_Sector_Ct   0x0033   098   098   036    Pre-fail  Always       -       54
  7 Seek_Error_Rate         0x000f   081   060   030    Pre-fail  Always       -       141318988
  9 Power_On_Hours          0x0032   088   088   000    Old_age   Always       -       10851
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0033   098   098   020    Pre-fail  Always       -       2468
183 Runtime_Bad_Block       0x0032   100   253   000    Old_age   Always       -       0
184 End-to-End_Error        0x0033   100   100   097    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   029   029   000    Old_age   Always       -       71
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   057   048   045    Old_age   Always       -       43 (Min/Max 34/44)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       224
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       48
193 Load_Cycle_Count        0x0032   081   081   000    Old_age   Always       -       39175
194 Temperature_Celsius     0x0022   043   052   000    Old_age   Always       -       43 (0 8 0 0 0)
195 Hardware_ECC_Recovered  0x001a   050   045   000    Old_age   Always       -       141410193
196 Reallocated_Event_Count 0x0033   098   098   036    Pre-fail  Always       -       54
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       4
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 68 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	SC = Sector Count Register [HEX]
	SN = Sector Number Register [HEX]
	CL = Cylinder Low Register [HEX]
	CH = Cylinder High Register [HEX]
	DH = Device/Head Register [HEX]
	DC = Device Command Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 68 occurred at disk power-on lifetime: 10720 hours (446 days + 16 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 08 ff ff ff 4f 00      02:50:36.466  READ FPDMA QUEUED
  61 00 a0 e0 a4 54 4e 00      02:50:36.466  WRITE FPDMA QUEUED
  60 00 10 50 25 d2 45 00      02:50:36.466  READ FPDMA QUEUED
  61 00 08 68 39 c6 42 00      02:50:36.465  WRITE FPDMA QUEUED
  ea 00 00 00 00 00 a0 00      02:50:36.465  FLUSH CACHE EXT
Error 67 occurred at disk power-on lifetime: 10720 hours (446 days + 16 hours)
  60 00 08 ff ff ff 4f 00      02:50:33.990  READ FPDMA QUEUED
  60 00 20 00 25 d2 45 00      02:50:33.990  READ FPDMA QUEUED
  61 00 08 ff ff ff 4f 00      02:50:33.989  WRITE FPDMA QUEUED
  ea 00 00 00 00 00 a0 00      02:50:33.885  FLUSH CACHE EXT
  60 00 10 f0 24 d2 45 00      02:50:33.883  READ FPDMA QUEUED
Error 66 occurred at disk power-on lifetime: 10720 hours (446 days + 16 hours)
  60 00 08 ff ff ff 4f 00      02:50:31.418  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00      02:50:31.399  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00      02:50:31.377  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00      02:50:31.376  READ FPDMA QUEUED
Error 65 occurred at disk power-on lifetime: 10720 hours (446 days + 16 hours)
  60 00 08 ff ff ff 4f 00      02:50:28.697  READ FPDMA QUEUED
  60 00 20 80 24 d2 45 00      02:50:28.697  READ FPDMA QUEUED
  61 00 58 ff ff ff 4f 00      02:50:28.697  WRITE FPDMA QUEUED
  61 00 08 ff ff ff 4f 00      02:50:28.696  WRITE FPDMA QUEUED
Error 64 occurred at disk power-on lifetime: 10720 hours (446 days + 16 hours)
  60 00 20 ff ff ff 4f 00      02:50:26.198  READ FPDMA QUEUED
  60 00 20 ff ff ff 4f 00      02:50:26.155  READ FPDMA QUEUED
  60 00 20 ff ff ff 4f 00      02:50:25.588  READ FPDMA QUEUED
  60 00 20 ff ff ff 4f 00      02:50:25.575  READ FPDMA QUEUED
  60 00 20 ff ff ff 4f 00      02:50:25.573  READ FPDMA QUEUED
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed: read failure       90%     10842         956697766
# 2  Short offline       Completed: read failure       70%     10842         956697766
# 3  Short offline       Completed: read failure       70%     10842         956697766
# 4  Extended offline    Interrupted (host reset)      00%       383         -
# 5  Short offline       Completed without error       00%       263         -
# 6  Extended offline    Completed without error       00%        53         -
# 7  Short offline       Completed without error       00%        50         -
# 8  Short offline       Completed without error       00%         1         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Востаннє редагувалось 23 січня 2016, 21:23 користувачем kol, всього редагувалось 1 раз.
Подякували: 2869 разів
Re: Посыпался винт? Гляньте на СМАРТ
Повідомлення Master » 22 січня 2016, 22:19
думаю - меняй пока не позно.
Повідомлення OlegLOA » 22 січня 2016, 22:26
Да, с винтом проблемы. Если еще на гарантии - то менять. Если не на гарантии - покупать новый
kol
Повідомлення kol » 22 січня 2016, 22:32
Спасибо. Есть ли смысл брать ССД для ноута на AMD E2-1800 + 8GM RAM ? Насколько ощутимым будет прирост производительности?
kol
Повідомлення kol » 22 січня 2016, 22:38
Я в игры не играю: офис, иногда вычисления, фильмы.
Повідомлення andrey_mix1982 » 22 січня 2016, 23:15
kol писав:Спасибо. Есть ли смысл брать ССД для ноута на AMD E2-1800 + 8GM RAM ? Насколько ощутимым будет прирост производительности?
SSD всегда есть смысл брать. А с офисными приложениями темболее.
Я как поставил ССД, то больше от него не откажусь. Винда загружаеться за 5-10 секунд (и это с драйверами и с всем остальным)
Все программы включаються мгновенно. Какбудто уже в памяти находяться за ранее.
Ставте 60-120 гб, и вам для ваших потребностей это будет с головой.
HDD это уже каменный век.
kol
Повідомлення kol » 22 січня 2016, 23:46
Торренты его не угробят?
Повідомлення andrey_mix1982 » 22 січня 2016, 23:50
kol писав:Торренты его не угробят?
Также как и HDD диски. И вообще это всё сказки. Может относилось к первым SDD
Не знаю, но вот у меня на SDD гарантия 60 месяцев, и не просто гарантия, а гарантия даже на так сказать если появявиться малейшая ошибка, износ и т.д
kol
Повідомлення kol » 22 січня 2016, 23:52
хм. Что за диск? На что обратить внимание при покупке?
Повідомлення OlegLOA » 22 січня 2016, 23:57
Угробят. К тому же для торрентов обьем маловат
